How to check your SSFP socket
Checking the SSFP socket
- Unplug anything that is plugged into any of your
telephone sockets on this line.
- Undo the 2 screws from the front of the socket.
- Pull the front plate of the socket away and you'll see
the test socket inside, on the bottom right.
- Plug a filter straight into the test socket and plug the
DSL cable into the router.
